Marzz
Mar 07, 2016Aspirant
Power Timer - do_exit+844
ReadyNAS 104 Firmware 6.4.2 4 disks (4x Seagate ST3000DM001 3TB disk) Power Timer is Enabled. Every night when my system should turn off, it goes to sleep in some sort of coma. It ignores the...
- Mar 13, 2016
Hi Marzz,
Welcome to the community!
Give the 6.5.0-T322 Beta Firmware a try and let us know if it fixes the issue.
Kind regards,
BrianL
NETGEAR Community Team
Marzz
Mar 13, 2016Aspirant
Unfortunately lowering the network settings to 1500 MTU didn't work.
My readynas still didn't respond in the morning after I set this parameter.
Now I disabled the power-timer as a workaround and I'll wait for the firmware update.
BrianL2
Mar 13, 2016NETGEAR Employee Retired
Hi Marzz,
Kind regards,
BrianL
- MarzzMar 15, 2016Aspirant
I installed the latest beta firmware 6.5.0-T322 yesterday and it worked.
In the morning the RN came alive again and the system log showed perfectly the shutdown and startup-line.
thank you very much ! :smileyhappy:
- BrianL2Mar 15, 2016NETGEAR Employee Retired
Hi Marzz,
Thank your for posting a positive feedback about NETGEAR's recently released Beta Firmware. This thread is now marked closed.
Kind regards,
BrianL
