Retired_Member
Jan 05, 2015Private Time Machine "volume" disappears
Hello and a happy New Year, I'm using private time machine on a ReadyNAS 104 running 6.2.2. In general the private time machine is working fine, but there's an issue after a scheduled ReadyNAS power...
Leofwine
Jan 15, 2015Tutor
I have just had the same problem after rebooting my RN102 through the web interface. I tried backing up several times which all failed with no given reason then I just reselected my Time Machine volume, re-authorised and it seems to be working now - at least it is part way through a backup.
- JsabouretAug 21, 2015Initiate
Hello,
I experienced the same, I have a MakBookPro with Yosemite and aReadyNas 104 OS 6.2.5.
As long as both systems are on the time Machine is reachable and working fine. As soon as the MAc or the NAS went down or move to sleep, the time Machine is gone and I have to disasble the service and re enable it on the ReadyNas before any backup can work again. This behavior occur only since ReadyNas Version 6.2.2 before that all was working fine.
I definitely see the issue in the REadyNas software.
