stratman4300
Mar 25, 2015Aspirant
Pro 2 disappears permanently from RAIDAR after setup
Hello all! Been banging my head against the wall on this one. We've got a pro 2 that used to work with no issues. Used to run file shares off of it and iSCSI for the lab at times. At any ra...
Mar 25, 2015Guru - Experienced User
You can also put the drives in a PC and delete the partitions. Then reinsert them into the NAS and it will certainly do a reset.
You can do a disk test from the front panel w/o doing a factory reset. The boot menu is on page 12 of the attached: http://www.readynas.com/download/docume ... pril11.pdf
