stratman4300
Mar 25, 2015Aspirant
Pro 2 disappears permanently from RAIDAR after setup
Hello all! Been banging my head against the wall on this one. We've got a pro 2 that used to work with no issues. Used to run file shares off of it and iSCSI for the lab at times. At any ra...
stratman4300
Thanks for the replies all!
I did one more factory reset to get it to show up in RAIDAR once again and now I'm running an erase operation, which is going to take a bit. Once that is done, I'll run a ReadyNAS disk check.
Outside of that, I'll attach the disks to a PC and remove the partitions and run health checks on them if the above doesn't yield some results.
Will report back later.
Thanks again!
Thanks again!
