turbowhite87
Oct 09, 2016Aspirant
Problem between ReadyNAS ultra 2 and Netgear D6300 router
Hello everybody! It is the first time I write on the forum but I read several times your discussion to fix problem in the past. This time I did not find anything helpful and I decided to ask you...
Oct 09, 2016Guru - Experienced User
What firmware is the NAS running?
Is the IP configuration set to use DHCP ("automatic") with jumbo frames off?
What is the NIC led status of the NAS when connected to your laptop? Also what is the NIC led status when connected to the router?
