ReadyNDSI
Nov 29, 2011Aspirant
problem between Utorrent and NAS
OKay... so I wanted to download with Utorrent on PC to NAS... (reason bittorrent downloads everything from scratch makes ratio hurting with updating files as it downloads every file since it does not do a filescan/check.)
I only download from private trackers.
But now I run into the following error/problem...
Dutch: (Fout: Aanmeldingsfout: onbekende gebruikersnaam of ongeldig wachtwoord.)
English: (error: login error: unknown username or unknown password.) [roughtly translated]
So how can it be solved?
ps. running on a ReadyNAS Duo, it worked before... i just puzzled to how/why/what happend.
Thanks in advance.
Thanks in advance.
- sphardy1ApprenticeWhat is generating the error? If uTorrent on your PC I'm unsure how this is a ReadyNAS issue
- ReadyNDSIAspirantUtorrent is on my PC.
What I do is:
1. Utorrent is always running 24/7, (since my PC runs 24/7 aswell)
2. I go to a private tracker and select a torrent, and the torrent is loaded into Utorrent.
3. I select the NAS location as download location.
4. after significant amount of time the message appears:
5. no other torrent client is running. - ewokNETGEAR ExpertAny problems accessing the NAS outside of uTorrent?
- ReadyNDSIAspirantNope, well had a small downtime with FTP, but after a bit of fiddle it worked again, so does utorrent recreated shortcuts and what not. also it's nice to see download speed ~10mb/s to NAS rather then the internal bittorrent client with a max of 2mb/s :D alot happier again now
- Mar 10, 2018Retired_Member
