marcusp
Jan 18, 2020Tutor
Problem with BTRFS filesystem
Greetings all, recently I noticed my rsync backups were having errors, so I've investigated and here is what I'v found until now: from status.log it seems the problem occured just after the d...
Jan 18, 2020Guru - Experienced User
It looks to me like the error happened quite a while after the balance you ran on the 9th of December. Did you look for disk errors in the log around 22 December (when the corrupt file system problem first showed up)?
Is the volume set to read-only?
- marcuspJan 18, 2020Tutor
Thanks for you answer Stephen. From what I remember the BTRFS errors are the source of the rsync backup errors that began on the 9th of december. I only published the errors of kernel.log from the 22th because I don't have the file from the 9th.
What kind of disk errors are you talking about ? SMART errors or BTRFS ?
I've searched in the log files for read only volume, but I haven't found anything relevant. Could you indicate me in which logfile I could find this info ?
- StephenBJan 18, 2020Guru - Experienced User
SMART errors are in disk_info.log. You'd look for disk and btrfs errors in system.log, kernel.log, and dmesg.log.
Are the errors happening in multiple shares, or just one? I suspect you can find out by just trying to copy a file into each share, and if that succeeds then deleting it.
