Retired_Member
Jul 31, 2011Problem with RAIDar finding Readynas ultra 2 plus
Hi - I am an absolute newbie and really struggling to get RAIDar to recognize my readynas. When begining installation yesterday I installed a single drive (Seagate Barracuda LP 2TB ST2000DL003) and...
sphardy1
Jul 31, 2011Apprentice
Considering
1. You can access Frontview via a direct connect
2. You state there is no Firewall operating
3. You have recently upgraded your firmware which means the NAS software should be OK
RAIDar should therefore work and I've not encountered such a situation where it does not (You are running RAIDar while directly connected right?)
Last 2 options are 1) Factory Reset 2) contact Tech Support
There are ways to diagnose this further but are beyond what a user should typically be expected to try.
Note that a factory reset will ensure you have a good NAS firmware setup, but will erase any data on your NAS. Details of how to do this are in the FAQ
