290373m
Sep 05, 2013Aspirant
Problem with second hand readynas duo V2
Hello, this is my first post in here so please don't kill if people have already asked this. I have purchased a second hand Readynas Duo V2. It has had a 1TB drive in it. I removed the drive and i...
Sep 06, 2013Guru - Experienced User
ok. First of all you have a v1, not a v2 (and yes, I know it probably says v2 on the label). Check here: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/ You might want to update your profile.
Try using the IP address instead of nas-9a-92-62
