WillidsNet
May 27, 2020Aspirant
Problem with Shares
I have setup the accounts and shares, I need a couple of folders protecting from anyone else on the network. When I go to the PC and view Network > Named Network > I see , All Folders, data (fol...
Marc_V
May 27, 2020NETGEAR Employee Retired
Welcome to the Community!
You will have to set permissions on the shares. Here's a good FAQ page for that.
https://kb.netgear.com/29838/ReadyNAS-Share-and-Permission-FAQ
HTH
WillidsNet
HTH
Thank you for the reply, I have tried that and other users can still see it and gain access to it.
- StephenBMay 27, 2020Guru - Experienced User
If your users are seeing the "data" folder, then they are using the NAS admin credentials. If you want to restrict their access, they need to use different credentials.
First create at least one new NAS account for them to use in the web ui. Then change the NAS admin password so their current admin credential will fail.
Then test access to the shares using the new NAS accounts.
I'm not sure exactly what you tried, but I recommend managing share access using network access rights alone (leaving the file access permissions at the default settings). https://kb.netgear.com/26453/ReadyNAS-OS-6-Set-Network-Access-Rights-to-Shared-Folders
- WillidsNetMay 27, 2020Aspirant
StephenB wrote:
WillidsNet wrote:Thank you for the reply, I have tried that and other users can still see it and gain access to it.
Once I get that sorted out, is there a way to encrypt the customer information (folder) ?
- SandsharkMay 27, 2020Sensei
WillidsNet wrote:
Once I get that sorted out, is there a way to encrypt the customer information (folder) ?No. You can only encrypt whole volumes. I use Veracrypt to encrypt sensitive data. I run it on the PC, not the NAS, with the container only on the NAS. One potential issue with you using this method is that only one person can open a Veracrypt volume at a time. BTW, if you go this way, turn off ":strict sync" for the share contining the Veracrypt container, and writes will be 500% faster.
Another thing that may be creating some of your issues is that DLNA does not abide by user permissions. To keep anyone with access to the NAS from getting to a share, DLNA must be disabled for that share.
