Stalin66
Oct 23, 2024Aspirant
Problem with start readynas pro 6 on OS 6.10.9
Recently updated OS from 4.2.3 to 6.10.9. Everything was fine for a few days, but yesterday it refused to load. Writes on display “Booting 50% (29%, 30%, 31%) wrote. Several reboots and hours of wait...
Oct 23, 2024Guru - Experienced User
Stalin66 wrote:
From the actions - I installed the FLEX server, but it is unlikely to be the cause ...
Do you mean plex? Did you upgrade the RAM in the Pro 6 when you converted it to run OS-6?
Stalin66
Yes, of course, PLEX)
I upgraded NAS a long time ago. The RAM was expanded to 4 GB. The processor was installed Intel Core 2 Duo E6600. + the power supply is new!
- Stalin66Oct 24, 2024Aspirant
Friends, we really need your support!
I really don't want to do a factory reset...
- StephenBOct 24, 2024Guru - Experienced User
Only Netgear can access the NAS remotely when you are in tech support mode...
RAIDar has both a diags option and a way to download the log zip. So you could try that.
If you are familiar with ssh, you could log in when the system is in tech support mode, and attempt to troubleshoot from there.
I have Raidar 6.5., but I found there the functions of downloading logs from the NAS
There is no experience and knowledge with SSH(((
