Stalin66
Oct 23, 2024Aspirant
Problem with start readynas pro 6 on OS 6.10.9
Recently updated OS from 4.2.3 to 6.10.9. Everything was fine for a few days, but yesterday it refused to load. Writes on display “Booting 50% (29%, 30%, 31%) wrote. Several reboots and hours of wait...
Stalin66
Yes, of course, PLEX)
I upgraded NAS a long time ago. The RAM was expanded to 4 GB. The processor was installed Intel Core 2 Duo E6600. + the power supply is new!
Stalin66
Oct 24, 2024Aspirant
Friends, we really need your support!
I really don't want to do a factory reset...
- StephenBOct 24, 2024Guru - Experienced User
Only Netgear can access the NAS remotely when you are in tech support mode...
RAIDar has both a diags option and a way to download the log zip. So you could try that.
If you are familiar with ssh, you could log in when the system is in tech support mode, and attempt to troubleshoot from there.
- Stalin66Oct 24, 2024Aspirant
I have Raidar 6.5., but I found there the functions of downloading logs from the NAS
There is no experience and knowledge with SSH(((
Not sure what you are saying. Do you mean that the diags and download logs functions aren't working?
Probably best to just bite the bullet and proceed with the reset.
Though if you want to try and mount the volume manually from tech support mode, I can give you some commands via PM.
