SgtUnit
Jan 13, 2016Aspirant
Problems upgrading drives in RN 104
Hi guys, I have a RN 104 that had 4 x 2tb drives in it, and recently acquired 4 x WD Red 4tb drives. Everything was going smoothly with upgrading the drives, the first one started almost righ...
mdgm-ntgr
Jan 14, 2016NETGEAR Employee Retired
Do you have a backup?
I would advise updating your backup before replacing disks one by one to expand your volume.
When you replace a disk the resulting resync puts heavy stress on all the disks. If a disk you don't replace is failing unbeknownst to you then you can run into problems. RAID-5 can withstand a single disk failure, but when you replace a disk the volume is degraded until the sync completes.
This sounds like something which would require a support case to investigate, but there would be some costs involved.
SgtUnit
Jan 14, 2016Aspirant
No, I don't have a backup :(
OK, I might need to get in touch with the support team then - thanks for your help.
Cheers,
Wayne
- JennCJan 14, 2016NETGEAR Employee Retired
Hello SgtUnit,
I guess you really have to. You may also need to avail their data recovery contract.
