Trally's avatar
Trally
Product site for ReadyNAS RNDU2000 shows available for Radiator 4.2.30 but not in release notes
I am trying to determine if I can upgrade from the exisiting Radiator level 4.2.15 to a later level hopefully 4.2.30   Any advice experience would be most welcome as the model is not listed in the ...
  • StephenB's avatar
    May 12, 2017
    mdgm wrote:
    I would suggest backing up your data before installing the firmware update(s).
    Always good advice, but I think it's especially important in your situation.  4.2.15 was released back in 2010...
ProSupport for Business
