Trally
May 12, 2017Aspirant
Product site for ReadyNAS RNDU2000 shows available for Radiator 4.2.30 but not in release notes
I am trying to determine if I can upgrade from the exisiting Radiator level 4.2.15 to a later level hopefully 4.2.30 Any advice experience would be most welcome as the model is not listed in the ...
May 12, 2017Guru - Experienced User
mdgm wrote:
I would suggest backing up your data before installing the firmware update(s).
Always good advice, but I think it's especially important in your situation. 4.2.15 was released back in 2010...
Trally
May 15, 2017Aspirant
Hi Guys
Thank you for the response - Will definitely do the back-up first
Regards...
