IcyK
Aug 29, 2015Tutor
Q: how to re-assemble RAID5 array
After some stupid action (described here) I lost a RAID5 volume (4 x 6TB, OS 4.2.27). The partitions vanished from the partition table. No warranty, no backup. It would be nice (though not essential)...
mdgm-ntgr
Aug 29, 2015NETGEAR Employee Retired
You could try forcing the array online but you may wish to clone your disks first. If you coyountact support you could purchase a data recovery attempt where support would attempt to recover your data.
What is the SMART stats of your disks like?
Edit: Oops. I confused the creation time with the update time.
mdgm-ntgr
Before you try forcing it to start, what is the output of the following?
# cat /proc/partitions
# for i in /dev/sd[a-z]; do echo $i; smartctl -a $i | egrep "Model|Firm|Sector|Hours|Error|Uncorr"; done;
