rcanpolat
Nov 03, 2013Aspirant
Question about mounting a drive on ReadyNAS 102
Hi guys, I got myself a ReadyNAS 102 running 6.1.4 yesterday - yay! Currently i have a single 2tb drive in the NAS. I want to offload media from a 1tb drive onto the nas's 2tb drive. I have t...
Nov 04, 2013Guru - Experienced User
If you install the 1TB drive into the NAS it will be wiped. So I think you will need a SATA->USB adapter that includes a power supply. There are such several adapter kits available - here is one: http://www.amazon.com/Vantec-NexStar-Ad ... B0064I1OFW
Afterwards, if you can switch to flex-raid you can install the drive in the second slot and set it up as a second volume. If the drive is not on the HCL, Netgear can/will deny support.
