peter2011
Sep 03, 2015Aspirant
Quota check slow and worse problems
I have a ReadyNAS Pro 6 running 4.2.21 I kept getting warnings of disk errors which quickly increased to large numbers: Disk 2: Previous count: 6112 Current count: 6696 ATA error count has...
Sep 03, 2015Guru - Experienced User
It's a bit hard to tell which disk(s) has rising reallocated sectors from your snippet. That drive should definitely be replaced first (and right away).
ATA errors are a bit more slippery, and sometimes can be collateral damage from the main failure. So you could hold off on that one and see if it settles down. Or just replace it both.
The main thing is to back up your data while you still can access it. If you no longer can (and have no backup) then opening a support case makes sense.
Netgear will likely charge for recovery, so you should establish a figure in your mind on how much your data is worth to you. Hopefully you'll stay well below that figure (but its useful to know what is).
peter2011
Sep 04, 2015Aspirant
Thanks both for your replies
A couple more points that might change the approach.
Firstly my six disk RAID has double-redundancy.
Secondly the large error number on disk six is very recent. It started very small recently then went mad.
Thirdly, I have six green lights on RAIDar and until I started the reboot/quota check I could access the volume.
Fourthly, the quota check has advanced overnight to 9.6%.
Fifthly, I have an almost complete backup.
My preference is just to slap in a new disk six, if that is not going to cause damage while the quota check is ongoing, but I don't know whether that is advisable.
Any further thoughts would be welcome.
Peter
- vandermerweSep 04, 2015Master
I'd reboot, then hot swap disk 6.
It sounds like you will have to use the front button.
- StephenBSep 04, 2015Guru - Experienced User
peter2011 wrote:
... my six disk RAID has double-redundancy.
Definitely a good thing in this case.
...the large error number on disk six is very recent. It started very small recently then went mad.
That's usually been my experience with failing disks. They go very quickly. So I replace them aggressively - the odds that a handful of bad sectors will just stay stable is low enough that I don't want to risk it.
...My preference is just to slap in a new disk six, if that is not going to cause damage while the quota check is ongoing, but I don't know whether that is advisable.
I don't use quotas, so I'm not sure if rebooting will simply terminate the quota check, or if it will restart. If it will just terminate, then reboot is a good idea. Likely the quota check can be killed with ssh also (if you have that enabled).
Is the volume status degraded? If you do have redundancy then perhaps start with just removing disk 6, and see if the quota check runs faster. Your speed issue (and resync failure) might simply be due to the failed disk. That will also give you a chance to assess the ATA situation on disk 2.
- peter2011Sep 05, 2015Aspirant
Thanks for everyone's help.
I shut down and swapped out disk 6, then rebooted and it resynced in a few hours as expected.
All well after that.
Now doing disk 2.
