Mark35
Apr 21, 2016Aspirant
R104 - power supply working but unit dead
Hi I have a Readynas 104 about 2 years old and it has just stopped working and will not power up. The power adaptor is showing a green light suggesting it is fine but the box itself is dead. Any ideas...
- Apr 27, 2016
The models ending in E are bundled with enterprise drives and the ones ending in D are bundled with desktop drives.
JennC
Apr 21, 2016NETGEAR Employee Retired
Hello Mark35,
Welcome to the community!
Unless the cord of the power adapter is not plugged in right to the ReadyNAS chassis, it is faulty.
If you are going to move the disks to another NAS, it should be the same exact model of ReadyNAS and FW version. Take note of the order of the disks too, they should be inserted to the same bay, to their respective bays, it is best you label them. It should be done by inserting them all at the same time while the ReadyNAS chassis is powered off.
Please contact support center to check the warranty of the ReadyNAS chassis.
