RealityDev
May 20, 2019Aspirant
RAID 1 resync incredibly slow
I would've replied to this thread but I don't see any options to reply. https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-4312X-Initial-Sync-Incredibly-Slow/td-p/1312492
RealityDev
The firmware version is 6.10.0 and logging in as root allowed me to change the settings. However it doesn't seem like the settings make any difference, it's still ultra slow at over 140 hours to sync a 4TB mirrored RAID. I can't believe Netgear does not optimize the device to sync faster than this, people are okay with taking a week or more to do something that should take less than a day?
May 21, 2019Guru - Experienced User
It shouldn't take a week for 2x4TB so I think something is wrong.
What disks are you using (manufacturer and model)?
Have you looked at the smart stats for both disks?
# smartctl -x /dev/sda
# smartctl -x /dev/sdb
The -x will give you some data on recent failed commands, which I think is relevant here.
- RealityDevMay 21, 2019Aspirant
The drives we are using are the following:
Western Digital WD4000FYYZ ENTERPRISE 4TB 7200RPM, 64MB Cache SATA 6.0Gb/s 3.5"
Drive 1:
root@nas1:~# smartctl -x /dev/sda
smartctl 6.6 2017-11-05 r4594 [armv7l-linux-4.4.163.alpine.1] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org=== START OF INFORMATION SECTION ===
Model Family: Western Digital Re
Device Model: WDC WD4000FYYZ-05UL1B0
Serial Number: WD-WMC130D3C11E
LU WWN Device Id: 5 0014ee 0ae925986
Firmware Version: 00.0NS05
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue May 21 09:13:42 2019 PDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is: Disabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSEDGeneral SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (46080) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 497) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 253 253 021 - 5541
4 Start_Stop_Count -O--CK 100 100 000 - 12
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 100 253 000 - 0
9 Power_On_Hours -O--CK 100 100 000 - 256
10 Spin_Retry_Count -O--CK 100 253 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 12
16 Total_LBAs_Read -O---K 000 200 000 - 7480455366
183 Runtime_Bad_Block -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 200 200 000 - 11
193 Load_Cycle_Count -O--CK 200 200 000 - 0
194 Temperature_Celsius -O---K 112 106 000 - 40
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 100 253 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warningGeneral Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x08 GPL R/O 2 Power Conditions log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x24 GPL R/O 1 Current Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb1 GPL,SL VS 1 Device vendor specific log
0xb2 GPL VS 65535 Device vendor specific log
0xb2 SL VS 255 Device vendor specific log
0xb3-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 24 Device vendor specific log
0xd0 GPL VS 1 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data TransferSMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors LoggedSMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
SCT Support Level: 1
Device State: Active (0)
Current Temperature: 40 Celsius
Power Cycle Min/Max Temperature: 40/43 Celsius
Lifetime Min/Max Temperature: 24/46 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (126)Index Estimated Time Temperature Celsius
127 2019-05-21 01:16 41 **********************
... ..(257 skipped). .. **********************
385 2019-05-21 05:34 41 **********************
386 2019-05-21 05:35 40 *********************
... ..(217 skipped). .. *********************
126 2019-05-21 09:13 40 *********************SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 1 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 1 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 67670 Vendor specific - RealityDevMay 21, 2019Aspirant
Drive 2:
root@nas1:~# smartctl -x /dev/sdb
Serial Number: WD-WCC13JSVRE5D
LU WWN Device Id: 5 0014ee 2b54a011d
Local Time is: Tue May 21 09:14:53 2019 PDT
was never started.
been run.
data collection: (46800) seconds.
command.
power-saving mode.
recommended polling time: ( 506) minutes.
1 Raw_Read_Error_Rate POSR-K 106 067 051 - 310
3 Spin_Up_Time POS--K 253 251 021 - 5583
4 Start_Stop_Count -O--CK 100 100 000 - 36
5 Reallocated_Sector_Ct PO--CK 194 194 140 - 211
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 100 100 000 - 257
12 Power_Cycle_Count -O--CK 100 100 000 - 27
16 Total_LBAs_Read -O---K 000 200 000 - 6988914804
192 Power-Off_Retract_Count -O--CK 200 200 000 - 23
193 Load_Cycle_Count -O--CK 200 200 000 - 12
194 Temperature_Celsius -O---K 111 105 000 - 41
196 Reallocated_Event_Count -O--CK 199 199 000 - 1
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
Device Error Count: 310 (device log contains only the most recent 24 errors)
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.Error 310 [21] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
When the command that caused the error occurred, the device was active or idle.After command completion occurred, registers were:
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 00 00 00 00 02 cc 10 5f 40 00 Error: UNC at LBA = 0x02cc105f = 46927967Commands leading to the command that caused the error were:
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 02 90 00 78 00 00 02 cc 2d d0 40 08 1d+04:45:31.977 READ FPDMA QUEUED
60 05 40 00 70 00 00 02 cc 28 90 40 08 1d+04:45:31.977 READ FPDMA QUEUED
60 02 c0 00 68 00 00 02 cc 25 d0 40 08 1d+04:45:31.977 READ FPDMA QUEUED
60 05 40 00 60 00 00 02 cc 20 90 40 08 1d+04:45:31.977 READ FPDMA QUEUED
60 02 c0 00 58 00 00 02 cc 1d d0 40 08 1d+04:45:31.977 READ FPDMA QUEUEDError 309 [20] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
40 -- 51 00 00 00 00 02 cb d0 e0 40 00 Error: UNC at LBA = 0x02cbd0e0 = 46911712Commands leading to the command that caused the error were:
60 00 08 00 80 00 00 02 cb d0 e0 40 08 1d+04:45:30.253 READ FPDMA QUEUED
60 00 08 00 78 00 00 02 cb d0 d8 40 08 1d+04:45:30.253 READ FPDMA QUEUED
60 00 08 00 70 00 00 02 cb d0 d0 40 08 1d+04:45:30.253 READ FPDMA QUEUED
60 00 08 00 68 00 00 02 cb d0 c8 40 08 1d+04:45:30.252 READ FPDMA QUEUED
60 00 08 00 60 00 00 02 cb d0 c0 40 08 1d+04:45:30.252 READ FPDMA QUEUEDError 308 [19] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
60 04 20 00 f0 00 00 02 cb cc f0 40 08 1d+04:45:29.069 READ FPDMA QUEUED
60 00 08 00 e8 00 00 02 cb ca e8 40 08 1d+04:45:29.067 READ FPDMA QUEUED
60 00 08 00 e0 00 00 02 cb ca e0 40 08 1d+04:45:29.067 READ FPDMA QUEUED
60 00 08 00 d8 00 00 02 cb ca d8 40 08 1d+04:45:29.066 READ FPDMA QUEUED
60 00 08 00 d0 00 00 02 cb ca d0 40 08 1d+04:45:29.066 READ FPDMA QUEUEDError 307 [18] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
40 -- 51 00 00 00 00 02 cb c6 64 40 00 Error: UNC at LBA = 0x02cbc664 = 46909028Commands leading to the command that caused the error were:
60 00 08 00 d0 00 00 02 cb c6 60 40 08 1d+04:45:27.356 READ FPDMA QUEUED
60 00 08 00 c8 00 00 02 cb c6 58 40 08 1d+04:45:27.356 READ FPDMA QUEUED
60 00 08 00 c0 00 00 02 cb c6 50 40 08 1d+04:45:27.356 READ FPDMA QUEUED
60 00 08 00 b8 00 00 02 cb c6 48 40 08 1d+04:45:27.356 READ FPDMA QUEUED
60 00 08 00 b0 00 00 02 cb c6 40 40 08 1d+04:45:27.355 READ FPDMA QUEUEDError 306 [17] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
40 -- 51 00 00 00 00 02 cb bb e8 40 00 Error: UNC at LBA = 0x02cbbbe8 = 46906344Commands leading to the command that caused the error were:
60 00 08 00 f0 00 00 02 cb bb e8 40 08 1d+04:45:23.847 READ FPDMA QUEUED
60 00 08 00 e8 00 00 02 cb bb e0 40 08 1d+04:45:23.847 READ FPDMA QUEUED
61 00 08 00 e0 00 00 02 cb bb e0 40 08 1d+04:45:23.290 WRITE FPDMA QUEUED
ef 00 10 00 02 00 00 00 00 00 00 a0 08 1d+04:45:23.268 SET FEATURES [Enable SATA feature]
27 00 00 00 00 00 00 00 00 00 00 e0 08 1d+04:45:23.268 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]Error 305 [16] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
40 -- 51 00 00 00 00 02 cb bb e7 40 00 Error: UNC at LBA = 0x02cbbbe7 = 46906343Commands leading to the command that caused the error were:
60 00 08 00 80 00 00 02 cb bb e0 40 08 1d+04:45:22.138 READ FPDMA QUEUED
60 00 08 00 78 00 00 02 cb bb d8 40 08 1d+04:45:22.138 READ FPDMA QUEUED
60 00 08 00 70 00 00 02 cb bb d0 40 08 1d+04:45:22.138 READ FPDMA QUEUED
60 00 08 00 68 00 00 02 cb bb c8 40 08 1d+04:45:22.138 READ FPDMA QUEUED
60 00 08 00 60 00 00 02 cb bb c0 40 08 1d+04:45:22.138 READ FPDMA QUEUEDError 304 [15] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
60 05 40 00 68 00 00 02 cb c5 b0 40 08 1d+04:45:20.985 READ FPDMA QUEUED
60 00 08 00 60 00 00 02 cb b6 78 40 08 1d+04:45:20.985 READ FPDMA QUEUED
60 00 08 00 58 00 00 02 cb b6 70 40 08 1d+04:45:20.985 READ FPDMA QUEUED
60 00 08 00 50 00 00 02 cb b6 68 40 08 1d+04:45:20.985 READ FPDMA QUEUED
60 00 08 00 48 00 00 02 cb b6 60 40 08 1d+04:45:20.985 READ FPDMA QUEUEDError 303 [14] occurred at disk power-on lifetime: 179 hours (7 days + 11 hours)
40 -- 51 00 00 00 00 02 cb b1 6b 40 00 Error: UNC at LBA = 0x02cbb16b = 46903659Commands leading to the command that caused the error were:
60 00 08 00 b8 00 00 02 cb b1 68 40 08 1d+04:45:19.255 READ FPDMA QUEUED
60 00 08 00 b0 00 00 02 cb b1 60 40 08 1d+04:45:19.255 READ FPDMA QUEUED
60 00 08 00 a8 00 00 02 cb b1 58 40 08 1d+04:45:19.255 READ FPDMA QUEUED
60 00 08 00 a0 00 00 02 cb b1 50 40 08 1d+04:45:19.254 READ FPDMA QUEUED
60 00 08 00 98 00 00 02 cb b1 48 40 08 1d+04:45:19.254 READ FPDMA QUEUEDSMART Extended Self-test Log Version: 1 (1 sectors)
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Current Temperature: 41 Celsius
Lifetime Min/Max Temperature: 18/46 Celsius
Vendor specific:
Temperature History Size (Index): 478 (202)Index Estimated Time Temperature Celsius
203 2019-05-21 01:17 41 **********************
... ..(292 skipped). .. **********************
18 2019-05-21 06:10 41 **********************
19 2019-05-21 06:11 40 *********************
... ..( 23 skipped). .. *********************
43 2019-05-21 06:35 40 *********************
44 2019-05-21 06:36 41 **********************
... ..(157 skipped). .. **********************
202 2019-05-21 09:14 41 **********************SCT Error Recovery Control:
0x8000 4 67742 Vendor specific- StephenBMay 21, 2019Guru - Experienced User
The ~300 errors on sdb are concerning. The ones in the disk cache are all UNCs (uncorrectable errors). That likely is enough to explain the slow sync time.
It isn't clear why they aren't showing up in the SMART stats - though I have run into this before on one of my own disks.
Anyway, I think this disk needs to be replaced - and that if you test it with Lifeguard (both the long read test and the full write-zeros test) you will find that is fails. At least that was the outcome with my own drive.
RealityDev wrote:
Drive 2:
Okay, running the extended test now with Lifeguard. I'm assuming this would give me some kind of report I could give to WD to get a replacement for a defective drive?
