Hans-Jakob
Nov 15, 2020Aspirant
Raid 5 is down after successful rebuild (replaced the drive)
Hi,
After replacing the degraded disk in my ReadyNas 516 (firmware 6.10.3) w/3x4TB WD RedWorrier NAS drives and after a reboot the all the discs shows up as spare (green and healty) but the raid 5 ...
Nov 15, 2020Guru - Experienced User
The disks look synced in mdstat.log
md127 : active raid5 sda3[0] sdc3[3] sdb3[4]
7804333568 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU]
bitmap: 1/30 pages [4KB], 65536KB chunk
Also, volume.log shows the resync completed in about 12 hours:
data disk test 2020-09-16 00:08:35 2020-09-16 08:07:37 fail Channel=2 Model=WDC_WD40EFRX-68WT0N0 Serial=WD-WCC4E2SUK42Z data resilver 2020-11-10 23:42:21 2020-11-10 23:43:33 degraded data resilver 2020-11-15 15:18:11 2020-11-16 03:37:19 completed
Does the volume tab show that the volume is redundant?
Hans-Jakob wrote:
but the raid 5 button on the right hand side is not on (X-RAID).
If you are talking about the X-RAID control, then X-RAID is enabled if there is a green stripe on the control.
If X-RAID isn't enabled, then it is safe to try to enable it. That won't trigger any RAID sync activity (and that is already finished).
I redacted your log links. Logs shouldn't be posted publicly (there is some privacy leakage when you to that).
