UCB's avatar
UCB
RAID 5 to RAID 1
Hello there, Upon adding a third hard disk (2TB) to my ReadyNAS 516 (OS version 6.7.5), it was automatically synced with an existing volume in RAID 5 (X-RAID). I would like to separate this disk, re...
  • cpu8088's avatar
    cpu8088
    Aug 19, 2017
    you may disable xraid and select flexiraid mode
    then add 4th drive and create a new volume in jbod, then copy all folders in original raid 5 to the 4th drive. after that u may destroy the raid 5 and recreate a new volume in raid 1. then copy all folders from 4th drive.
ProSupport for Business
