Focuses_Moments
Dec 01, 2012Aspirant
RAID configuration? (present and future)
Hi there ... kinda new to this and tried reading but it won't go through my head :) I have a new ReadyNAS NV+ with 2*2TB drives in it right now (this leaves 2 spare bays). Questions: 1. Is RAI...
Dec 01, 2012Guru - Experienced User
Do you have a v1 or a v2? Use this guide to tell: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
The broad answer to your question is that the NAS uses XRAID by default. If you didn't explicitly tell the NAS to use flex-raid, adding more drives will result in the NAS converting your RAID-1 array to Raid-5.
If you really want two RAID-1 volumes you will need to go through the setup again, this time choosing flex-raid. Note that will be starting over, wiping your data and config. I suggest reading the manual before doing this.
