kenya1
Jun 02, 2018Aspirant
RAIDar not dtecting my ReadyNAS Duo RND2110 V2
Hi
I have the ReadyNAS DUO RND 2110 V2 which has been working fine, I managed it through my PC.
My Windows PC recently crashed and I have bought a new PC.
I have installed RAIDAR 6.3 o...
Jun 02, 2018Guru - Experienced User
Try disabling any internet security software (including the windows firewall), and then re-run RAIDar.
What firmware is the NAS running?
Also, can you access the NAS with https (browser) or smb (file explorer?
kenya1
Jun 03, 2018Aspirant
Dear Stephen
Thank you for your response
I have diabled internet security and the windows firewall.
I think the NAS is running 4.1.6, how can I check it?
How can I access NAS with https (browser)?
- StephenBJun 03, 2018Guru - Experienced User
You can access the NAS admin web ui by entering https://nas-ip-address/admin in your browser (using the real NAS IP address of course). You will get a security warning in the browser that you need to click through. In the case of Chrome, you'd click on "advanced", and then continue on to the page. From there you will get a pop-up prompting for the username (admin) and password.
You'll find the firmware version on the home page of the NAS admin web ui.
- kenya1Jun 03, 2018Aspirant
hi Stephen
Thanks for your response
Just followed your instructions, and got to the NAS admin page but can't see the firmware version anywhere on that page, where would I find it?
- StephenBJun 04, 2018Guru - Experienced User
If you are running 4.1.6 firmware, then you have a v1 (sparc-based), not a v2 (arm-based). The labels are confusing, and many v1 owners do mistakenly believe they have a v2.
With a v1, you'll find the firmware on the home page as shown below (my screenshot is from a 4.2 system, but the layout is the same).
If you do have a v2 NAS, then you'll be seeing a very different screen (and will be running 5.x.x firmware, not 4.1.x). You'll see the dashboard overview page (which shows the current firmware) on page 12 of the v2 software manual here: http://www.downloads.netgear.com/files/GDC/READYNAS%20ARM-PLATFORM%20(DUO%20V2,%20NV+%20V2)/RAIDiator%205.3%20SW%20Manual_5Sep12.pdf
