AJSG1969
Feb 26, 2016Aspirant
RAIDiator 4.2.28 - "No space allocated for snapshots"
69% of capacity is used The snapshot tab states: "no space allocated for snapshots" Neither Time Machine nor Vault are enabled CHECKED Disable full data journaling CHECKED Disable journali...
- Mar 01, 2016
Snapshots work very differently on ReadyNAS OS6 to how they worked on RAIDiator-x86 4.2.x. The filesystem is different and with 4.2.x you have just the one snapshot. If you write more data than there is snapshot space then the snapshot will be invalidated.
Provided the Online Filesystem Check is scheduled at the appropriate time, 100GB should be way more than the amount of writes that take place during the time the snapshot is active.
mdgm-ntgr
Feb 27, 2016NETGEAR Employee Retired
When you do a factory default (wipes all data, settings, everything) there is a 10 minute countdown during which you can open RAIDar, choose the RAID mode and the amount of snapshot space you want and confirm your choice.
RAIDiator-x86 4.2.x support a single snapshot at a time.
AJSG1969
Mar 01, 2016Aspirant
Worked nicely, however I am limited to 100GB. Whilst on my 2120 I can go way above it.
Thanks.
- mdgm-ntgrMar 01, 2016NETGEAR Employee Retired
Provided the Online Filesystem Check is scheduled at the appropriate time, 100GB should be way more than the amount of writes that take place during the time the snapshot is active.- AJSG1969Mar 02, 2016Aspirant
Thank you very much for your help. I will have set them up as daily and am not going to add more than 100GB in total per day as I build up the backup Shares.
