omigod
Feb 19, 2013Aspirant
Raspberry Pi anyone?
In an effort to produce a cheap, small and quiet media streaming unit to replace my older, larger, and nosier pc units I have been having a bit of a look at the raspberry Pi. There is community of fo...
rocus
May 28, 2013Aspirant
I have a ReadyNas Duo and streaming with UPnP to the raspberry works fine. The raspberry will however not play any video format. But the raspberry can also mount filesystems (samba or NFS). If you like to use tags (in your mp3's) UPnP is the way to go but if you have a sensible directory structure or if you have no tags (as with video's) mounting is reliable and fast. I personally don't like Minidlna so much because it acts weird if I add a new directory to the scanned tree. (the database get mixed up)
