breconfirefight
Jan 08, 2018Aspirant
RD5200 Replicating to RD516
Hi all Hoping someone can help me with this, for the past two years i have been replicating my luns on the rd5200 to my rd516, the 5200 is in work and the 516 is at home, everything has been work...
mdgm-ntgr
Jan 09, 2018NETGEAR Employee Retired
Which firmware are you running?
breconfirefight
Jan 09, 2018Aspirant
The rd5200 is running 1.4.4 and the rd516 is running 1.4.3
- mdgm-ntgrJan 09, 2018NETGEAR Employee Retired
Well it could be a good idea to get both onto the same firmware revision 1.4.5. Another advantage of this is that if a disk fails out of warranty depending on the disk type you may be able to replace it with an unsigned disk.
