breconfirefight
Jan 08, 2018Aspirant
RD5200 Replicating to RD516
Hi all Hoping someone can help me with this, for the past two years i have been replicating my luns on the rd5200 to my rd516, the 5200 is in work and the 516 is at home, everything has been work...
breconfirefight
Jan 09, 2018Aspirant
The rd5200 is running 1.4.4 and the rd516 is running 1.4.3
mdgm-ntgr
Jan 09, 2018NETGEAR Employee Retired
Well it could be a good idea to get both onto the same firmware revision 1.4.5. Another advantage of this is that if a disk fails out of warranty depending on the disk type you may be able to replace it with an unsigned disk.
