Lauri
Oct 12, 2015Aspirant
Automatisk avstängning av NAS 102
Jag har NAS 102. Problemet är att det inte går att programmera automatiska avstängning av NAS:en. Jag har prövat olika inställningar vad gäller Diskavstänging och Timer för ström. På min andra Rea...
JennC
Oct 20, 2015NETGEAR Employee Retired
Hello Lauri ,
Welcome to the community!
We apologize for having this problem after the update.
Please try turning off the NAS then turn it back on, then re-apply the power timer schedule then test again.
Please let us know if you get the same results.
Lauri
Oct 21, 2015Aspirant
Hi Jenn
Your advice did not help. I have have the same problem left after several turn offs, reprogramming and re-starting of of NAS-102.
But i do not have any such problems with my older Ready NAS Duo v2
Regards // Lauri
- JennCOct 21, 2015NETGEAR Employee Retired
- LauriOct 21, 2015Aspirant
NAS-102 has firmware (fast programvara) 6.4.0
Regards // Lauri
Hello Lauri,
Was it working before?
I suppose you are referring to the Power Timer.
It may be best you contact support center to have this checked.
