joey123
Jan 29, 2017Tutor
BTRFS scrub speed is insanely slow.
So I have a RN104, with about 10TB of disk space. When I set it to do a BTRFS scrub, the speed is horrific. I'm getting something like 30GB/hour of scrub speed. At the present rate, it would take ...
aalexandrebeta
Feb 25, 2017Master
It's a hell of a mess you are into!!!!
Good luck and patience!!
Cheers!
joey123
Feb 25, 2017Tutor
Yeah, thanks.
The problem isn't devastating, because the NAS works just fine in every other way. I can even literally read every byte off it, and thus accomplish the scrub, in a reasonable amount of time. It's just the scrub functionality itself that is totally broken.
I guess let's see if Netgear tries to figure out a fix.
- aalexandrebetaFeb 25, 2017Master
joey123you are learning the hard way and learning fast!!!!
In front of those kinds of mess I fell like a complete moron (excuse my French and I am a Frog as you noticed the way I slaughter the Cheakspear language!):)!!!
