Borealis
Sep 11, 2015Aspirant
Compatibility list for DUO
ne of my harddrives went south. I have an old Ready NAS Duo (V1 or V2?) bought in 2010. How important is it that the new disk is on the compatibility list? Last, but not the least; where do I fin...
- Sep 11, 2015
Hello Borealis,
ReadyNAS Duov1 and ReadyNAS Duov2 are not the same. v1 is a Sparc based OS4 while v2 is an ARM based OS5.
See Hardware Compatibility List Hard Disks and select Legacy from the first drop down menu and then select ReadyNAS Duo (v1) or ReadyNAS Duo v2 from the second drop down menu. This will show the list of compatible disks.
Disk that is not listed on the HCL may or may not work with the ReadyNAS chassis, sometimes will work but not reliable that is why there is a list of compatible disks as these disks are the tested ones. Please also take note of the warning message on the page.
Borealis
Thanks a lot for your help, guys!
