AlexSem
Mar 17, 2026Aspirant
Help needed: ReadyNAS NVX (RNDX4000) Restore to RAIDiator 4.2 - Empty /boot_flash
Hi everyone, I’m reaching out because I made a major mistake while attempting to upgrade my ReadyNAS NVX (RNDX4000) from v4.2 to OS6. The upgrade failed, and now I'm trying to restore the unit ba...
- Mar 21, 2026
AlexSem wrote:
Do you see any possible options for recovering the NAS?Check your PMs (click on the envelope icon in the upper right of the forum page).
Sandshark
Mar 19, 2026Sensei
I'm still a little confused since you said you mounted the boot_flash directory. The actual boot flash is a hardware device (typically sde on a 4-drive unit, but likely something else if you are doing this without 4 drives installed) and is not automatically mounted. So did you mount the sde1 partition (or other device if it's different) to boot_flash?
Are you booting with drives installed? The OS has to install on at least one drive before the GUI works properly.
If RAIDar is properly showing the model name and serial number, then you do have an intact vpd file. I'm not sure how far OS4.2.31 gets in booting without a vpd file, so if RAIDar isn't showing that info, then the vpd may be the issue.
