AlexSem
Mar 17, 2026Aspirant
Help needed: ReadyNAS NVX (RNDX4000) Restore to RAIDiator 4.2 - Empty /boot_flash
Hi everyone, I’m reaching out because I made a major mistake while attempting to upgrade my ReadyNAS NVX (RNDX4000) from v4.2 to OS6. The upgrade failed, and now I'm trying to restore the unit ba...
- Mar 21, 2026
AlexSem wrote:
Do you see any possible options for recovering the NAS?Check your PMs (click on the envelope icon in the upper right of the forum page).
Mar 20, 2026Guru - Experienced User
AlexSem wrote:csums.md5 kernel memtest supplmnt.tlz version.txt
initrd.gz ldlinux.sys root.tlz syslinux.cfg
Ok. So the VPD is indeed missing.
I'm not sure if the vpd showing in in the root in Sandshark's guide is a folder, or whether it is the vpd file itself. I'm tagging him, so hopefully he will answer.
Sandshark
Mar 21, 2026Sensei
vpd is a file at root of the actual boot flash. There must not be a vpd directory since it can't co-exist with the vpd file. My guess is that /proc/sys/dev/boot/info is created by the boot process from the data in the vpd file. Given it's in /proc/sys, it has to be put there by the system -- it's not a file on a drive (at least not in that location) .
- AlexSemMar 21, 2026Aspirant
