somejoe
Jan 20, 2013Aspirant
NV+ disk swap failure
I was running out of room, was going to upgrade from 500MB to 2TB drives. Using WD RED, so compatible. Pulled the first disk and put in the new one. Ran through initialization, started sync, got to...
Rabbie
Jan 21, 2013Aspirant
I think maybe the disk 2 is fautly. It caused the resyncing failed to finish.
It is better give us a remote access to box, then we can have a check for the disk 2.
You also can try normal boot only with the disk 1 which you pulled before. Maybe the unit can boot up only with the disk 1. Then you can hot-plug new disk in box again.
