bedlam1
Mar 26, 2019Prodigy
OS 6.10 Release
Can anyone advise on how the new features added in OS 6.10 (Highlit in RED below) can be viewed/accessed ?
New Features and Enhancements:
ReadyTIER support for data tiering, including
Al...
Marc_V
Mar 27, 2019NETGEAR Employee Retired
The feature should be within the Share's setting under the Auto-defrag option and above the size/quota setting.There should also be a text link that says "Calculate"
This should be visible even if Quota is not enabled, please let us know if there are any issues.
Regards
OOM-9
Mar 27, 2019NETGEAR Expert
The Consumed space calculation has been removed from the UI at this time. We found a critical memory related issue with this feature just before we were releasing. We are working on a fix for this memory issue to bring the feature back in the up coming release.
- GG-71Mar 29, 2019Aspirant
After I updated from 6.9.5 to 6.10.0
the Admin Page show me no more antivirus
and I can not install any app.
Bug or feature?
I can not change permissions on shares. After I changed something and press [Apply] I get "Folder operation failed."
- Equinox1Apr 28, 2019Guide
Please hurry on the space calculation feature....that would be really useful. That said, I completely understand the criticality of memory and how hard they are to fix.
it would have been great to mention this removal on the release notes, though.
- ronaldvr2132Jun 15, 2019Apprentice
How can I edit the settings after I enabled the new audit in the logging section? I have activated it and saw you can select the details of which level and for which share it is enabled, but after applying the apply button I can't find the way to come back to these settings to verify and alter them if I want to do so.
