Ozchap
Sep 09, 2016Aspirant
OSStatus error 5
Hi community Keep getting this error 'OSStatus error 5' when trying to log in from my wife's macbook air. Have no issue with iMac desktop & our son's macbook pro. Want to backup her macbook ...
JennC
Sep 10, 2016NETGEAR Employee Retired
Hello Ozchap,
It must have nothing to do with ReadyNAS system you have. Can you post screenshot?
Welcome to the community!
Ozchap
Sep 10, 2016Aspirant
Thanks for your reply JennC
I would agree with you as it seems the 2011 MacBook Air is not accessing the ReadyNAS properly for Timemachine to work.
Please refer to the attached screenshot as requested.
1 - error message
2 - Finder directory (displays ReadyNas properly which can be accessed ok) HO-3TB-MA (AFP) for Mac. Files can be read & written to
3 - Timemachine does not display the drive it only refers to HO-3TB-MA without the (AFP) directory which is what is needed for the Mac.
Seems to me like I might need to contact AppleCare for support on this if there is an easy way otherwise I'll have to use another external drive.
- JennCSep 13, 2016NETGEAR Employee Retired
Hello Ozchap,
Can it access the NAS shares via SMB and/or AFP? Also, please make sure the MacBook is connected to the same network where the NAS is.
- OzchapSep 13, 2016Aspirant
Hi JennC
As in the previous post screen shot 2, access is fine on the AFP drive. Seems like Time Machine cannot access ReadyNAS properly, may have something to do with it being 5 years old as our sons 2015 macbook pro connected fine.
I will contact Apple for assistance or use a separate drive which is not ideal.
Thanks
- JennCSep 15, 2016NETGEAR Employee Retired
Hello Ozchap,
TimeMachine connects to NAS via AFP too. Maybe something needs to be adjusted with that TimeMachine of the Mac computer.
Just post back in case you have any updates.
