Ozchap
Sep 09, 2016Aspirant
OSStatus error 5
Hi community Keep getting this error 'OSStatus error 5' when trying to log in from my wife's macbook air. Have no issue with iMac desktop & our son's macbook pro. Want to backup her macbook ...
JennC
Sep 13, 2016NETGEAR Employee Retired
Hello Ozchap,
Can it access the NAS shares via SMB and/or AFP? Also, please make sure the MacBook is connected to the same network where the NAS is.
Ozchap
Sep 13, 2016Aspirant
Hi JennC
As in the previous post screen shot 2, access is fine on the AFP drive. Seems like Time Machine cannot access ReadyNAS properly, may have something to do with it being 5 years old as our sons 2015 macbook pro connected fine.
I will contact Apple for assistance or use a separate drive which is not ideal.
Thanks
- JennCSep 15, 2016NETGEAR Employee Retired
Hello Ozchap,
TimeMachine connects to NAS via AFP too. Maybe something needs to be adjusted with that TimeMachine of the Mac computer.
Just post back in case you have any updates.
- OzchapSep 17, 2016Aspirant
Hi JennC
I did a few tests with Applecare & confirmed that even though files can be read & written to from the 'Finder' window on the Macs, it is an access issue to the NAS drives when trying to sign in with Time Machine. Even when choosing either 'Registered User' or 'Guest' passwords seem to not be accepted.
I will have to go through the NAS manual to check how I can set up access with passwords to try & get this to work.
I will let you know how I go when I get a chance.
Thanks
Bill
