jeffvenuti
Oct 17, 2015Aspirant
Please Help: can't ssh, can't start services_case nos.: 25913382 / 25923232
My problems started this morning by getting this email message every 10 minutes:
System volume root usage is 81 %. This condition should not occur in normal conditions. Please contact technical...
DaneA
Oct 19, 2015NETGEAR Employee Retired
Hi jeffvenuti,
jeffvenuti wrote:
I do not have a backup of the data. But through the GUI I can see that the Shares are all there and data is accessible. If you can advise on how to backup this data I will do so. Can I do this through the GUI?
Are you able to access your data via SMB access using a PC/laptop? If yes, since you mentioned that the GUI does not seem to respond then you could manually backup the data by doing copy/paste from the NAS to an external drive or to a PC/laptop that has free space.
jeffvenuti wrote:
Since I don't want to lose any data I have not tried to perform a factory reset.
Ensure that you have a backup of your data first.
jeffvenuti wrote:
I don't know how to set the NAS to telnet mode. Never tried. I can access the GUI and under settings I can see all the services (SMB, HTTP, SSH etc.) but nothing seems to respond to being selected. Is this the same place telnet mode is selected?
Check this article on how to set the NAS to telnet mode (tech support mode).
DaneA
NETGEAR Community Team
jeffvenuti
Oct 19, 2015Aspirant
Hi DaneA,
I will try restarting into tech support boot mode when I get home this evening. How will I know if it has been successfull? Can I use putty to telnet into it or something like that?
If I can't enable SMB mode (which may be the case since I can't enable other services like SSH), then can I use "Volume Read only" boot mode to backup date? How does one access data in that case?
Thanks,
Jeff
- DaneAOct 21, 2015NETGEAR Employee Retired
Hi jeffvenuti,
It seems that a new case has been opened by NETGEAR Support that is related to your concerns mentioned here on this forum thread. It appears that your problem has been resolved as well. Kindly confirm.
DaneA
- jeffvenutiOct 21, 2015Aspirant
Hi DaneA,
A level 3 NetGear tech logged into my readyNAS 314 and noticed that something was wrong with /etc/fstab. He fixed that. Then I was able to ssh in and move my old var directory, which I had copied to /home/var, back to /var. Everything seems to be back to normal after that.
BUT, I still have the original problem where I'm getting warnings about the root partition getting full, which is why I attempted to move the /var folder someplace else. I still need help doing that. The first time I tried it I wound up getting locked out so obviously I need some help there.
Thanks,
Jeff
Hi jeffvenuti,
I am glad that the Level 3 expert has remotely fixed the problem and that everything seems to be normal.
With regard to this, I believe you may still asked the same Level 3 expert who helped you so that he can look into your NAS via a remote session again. Kindly use the same case number provided to you.
DaneA
No content to show
