jeffvenuti
Oct 17, 2015Aspirant
Please Help: can't ssh, can't start services_case nos.: 25913382 / 25923232
My problems started this morning by getting this email message every 10 minutes:
System volume root usage is 81 %. This condition should not occur in normal conditions. Please contact technical...
DaneA
Oct 21, 2015NETGEAR Employee Retired
Hi jeffvenuti,
It seems that a new case has been opened by NETGEAR Support that is related to your concerns mentioned here on this forum thread. It appears that your problem has been resolved as well. Kindly confirm.
DaneA
NETGEAR Community Team
jeffvenuti
Oct 21, 2015Aspirant
Hi DaneA,
A level 3 NetGear tech logged into my readyNAS 314 and noticed that something was wrong with /etc/fstab. He fixed that. Then I was able to ssh in and move my old var directory, which I had copied to /home/var, back to /var. Everything seems to be back to normal after that.
BUT, I still have the original problem where I'm getting warnings about the root partition getting full, which is why I attempted to move the /var folder someplace else. I still need help doing that. The first time I tried it I wound up getting locked out so obviously I need some help there.
Thanks,
Jeff
- DaneAOct 21, 2015NETGEAR Employee Retired
Hi jeffvenuti,
I am glad that the Level 3 expert has remotely fixed the problem and that everything seems to be normal.
With regard to this, I believe you may still asked the same Level 3 expert who helped you so that he can look into your NAS via a remote session again. Kindly use the same case number provided to you.
DaneA
No content to show
