6speed1
Jul 15, 2015Aspirant
ReadyNAS 1100 BLOD (Blue Light of Death)
I have a ReadyNAS 1100 running RAIDiator 4.1.14 with 4 2TB Seagate drives. It was running fine when I went to bed and when I got up it had a blue blinking light. RAIDar does not see it unless I ...
6speed1
Aug 12, 2015Aspirant
So after some help from mgdm, I cloned the failing drive and replaced the bad drive.
Raidar shows the system as up and healthy but the system led is still blinking slow blue and the drive LEDs are not on. I also can not access from Windows or a web browser.
So before I call tech support do you all have any ideas I should try first and what can I do to make sure my tech support call is as successful as possible?
- JennCAug 14, 2015NETGEAR Employee Retired
Hello 6speed1,
That may be not done yet after inserted the cloned disk I think there is something else left to do. PM back mdgm for next step.
- 6speed1Aug 15, 2015Aspirant
Thanks for the suggestion. :)
Turns out that the reset switch is either broken or stuck so my brother will have to fix that first before I try to fix it.
I 90% sure there is still an issue with the disk set because he has another 1100 that is working. I put the 4 disks from this 1100 in the working 1100 and get the same blinking blue light.
My next step is to try an OS Re-install for grins which is how I figured out the button is stuck.
Also, this support page mentions the abilty to do an offlne disk test but doesn't say how to do it.
Ideas?
