6speed1
Jul 15, 2015Aspirant
ReadyNAS 1100 BLOD (Blue Light of Death)
I have a ReadyNAS 1100 running RAIDiator 4.1.14 with 4 2TB Seagate drives. It was running fine when I went to bed and when I got up it had a blue blinking light. RAIDar does not see it unless I ...
JennC
Aug 14, 2015NETGEAR Employee Retired
Hello 6speed1,
That may be not done yet after inserted the cloned disk I think there is something else left to do. PM back mdgm for next step.
6speed1
Aug 15, 2015Aspirant
Thanks for the suggestion. :)
Turns out that the reset switch is either broken or stuck so my brother will have to fix that first before I try to fix it.
I 90% sure there is still an issue with the disk set because he has another 1100 that is working. I put the 4 disks from this 1100 in the working 1100 and get the same blinking blue light.
My next step is to try an OS Re-install for grins which is how I figured out the button is stuck.
Also, this support page mentions the abilty to do an offlne disk test but doesn't say how to do it.
Ideas?
