ajkainth
Oct 03, 2017Aspirant
ReadyNAS 212 \ snapshot note created automaticly
I have configured to create daily snapshot for a folder but it doesn't create even there is no error in log. If i create snapshot manually then it creates normally.
- Oct 12, 2017
These logs you provided us show that the option "Spin up disks to take scheduled snapshots" is not enabled. Go to System > Power > Disk Spin-down, check the box "Spin up disks to take scheduled snapshots" -- your disks are spun down, can't take snapshot, then 5 minutes later your disks wake up for backup jobs.
kohdee
Oct 12, 2017NETGEAR Expert
- Jun 06, 2017Retired_Member
