der_ger
Nov 25, 2017Guide
ReadyNAS Pro 4 [X-RAID2] looses connection to LAN repeatedly after update to RAIDiator 4.2.31
My Ready NAS Pro 4 looses accessability from the local LAN on transfer of larger amounts of data. A factory reset did not solve the problem. Restoring data from an USB-Disk works. My ReadyNAS Pro 4 ...
Nov 26, 2017Guru - Experienced User
The next time it happens, can you try disconnecting the ethernet cable from the NAS, and then reconnecting it? You should then see the IP address show up again on the NAS LCD display. Then try accessing the NAS again (without rebooting).
der_ger
Nov 26, 2017Guide
Hello,
I tried it, but this does not work. When the NAS gets inaccessible the IP-Adress remains displayed, only when disconnecting the LAN-cable it says, that there is no LAN connected. After dis- and reconnecting the IP-Adress ist shown again.
A fixed IP4-adress is assigned to the NAS by the router by using the MAC-adress of the NAS. The same IP4-adress is filled in as a value in the NAS setup menue.
Only powering the NAS off and switching it on again makes the NAS accessible again.
- StephenBNov 27, 2017Guru - Experienced User
Can you confirmed that you did a factory reset (destroying your data), and that didn't help? Or did you actually do an OS reinstall (which does not destroy your data)?
Also did you try the second NIC port on the Pro?
- der_gerNov 27, 2017Guide- Can you confirmed that you did a factory reset (destroying your data), and that didn't help? Hello StephenB: I definitely did a factory reset triggered from the settings-menue of the admin account. I had to type in "FACTORY" to confirm the reset. All data, settings and shares were deleted or reset. The NAS was accessible after the reset without any further problems. The available disk space was appoximately 10 GB smaller after the reset (snapshot function reseving 10 GB of data space was switched on before and after reset). You told me problems could result from a full operating partition, that's why I performed the factory reset. - Or did you actually do an OS reinstall (which does not destroy your data)? I faced some troubles to reinstall the OS, actually I failed to do so. I tried to reinstall the OS, as I suspected the update toRAIDiator 4.2.31 had some troubles, but any further attempt to reinstall the OS was refused, as the system told me that this already is the accurate version of the OS. So how to reinstall the OS by the way? - Also did you try the second NIC port on the Pro? This is defintely worth a try!
Thx, I wanted to make sure I didn't send you in circles. The NIC ports often fail together, but it is worth trying. There are some issues that only show up on one port (connector problems for instance).
der_ger wrote:
So how to reinstall the OS by the way?The reinstall procedure is page 21-22 here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
