der_ger
Nov 25, 2017Guide
ReadyNAS Pro 4 [X-RAID2] looses connection to LAN repeatedly after update to RAIDiator 4.2.31
My Ready NAS Pro 4 looses accessability from the local LAN on transfer of larger amounts of data. A factory reset did not solve the problem. Restoring data from an USB-Disk works. My ReadyNAS Pro 4 ...
bedlam1
Nov 27, 2017Prodigy
Have you considered upgrading your Pro 4 to latest OS 6 (since you have already factory defaulted and presumably have a full data backup)
Search the forum on how to do this
der_ger
Nov 28, 2017Guide
bedlam1 wrote:Have you considered upgrading your Pro 4 to latest OS 6 (since you have already factory defaulted and presumably have a full data backup)
Yes, I consider to upgrade to OS 6, but as this version is not not supported by the support, I will try to do anything else before upgrading to OS 6
