MarkPearce
Mar 24, 2017Aspirant
ReadyNas104 - SMB not starting File Ownership problems.
Hi All, Hope you can help me out, I have a level of technical knowledge in as much as I think I know what has happened somehow, but need some help in determining what I need to do to fix the prob...
Apr 04, 2017Guru - Experienced User
MarkPearce wrote:
What is the best way to get the log to you?
Note that FramerV is asking for the full log zip, not a manually created file. You can get that from RAIDar or via the web UI.
MarkPearce
Apr 04, 2017Aspirant
Thanks StephenB, I have sent the log off as suggested in the link.
