MarkPearce
Mar 24, 2017Aspirant
ReadyNas104 - SMB not starting File Ownership problems.
Hi All, Hope you can help me out, I have a level of technical knowledge in as much as I think I know what has happened somehow, but need some help in determining what I need to do to fix the prob...
JennC
Apr 18, 2017NETGEAR Employee Retired
Hi MarkPearce,
Please check PM that you have received from mdgm,
MarkPearce
Apr 24, 2017Aspirant
I am still having lots of issues, on top of not being able to start SMB a defrag has filled up the disk. I have stopped the defrag and am currently trying to grecefully reboot the NAS drive.
I noticed the following message in the logs as I am waiting for the system to shutdown :
Apr 24 12:49:01 AI-NAS cron[2100]: (*system*spindown) RELOAD (/etc/cron.d/spindown) Apr 24 12:49:01 AI-NAS cron[2100]: (root) WRONG FILE OWNER (crontabs/root)
It has still not shutdown just yet, but appear to be going, or so it says on the front of the drive.
Any further help would be much appreciated.....
Mark
P.s. I have sent messages to mdgm but not had any response, although i understand they are in a completely different timezone to me which may not help!
- MarkPearceApr 24, 2017Aspirant
OK, now I think I have lost my access. The Display now just shows :
kfree+14c
What does this mean? Is it space related as a swcheduled defrag had been runing ande filled up the drive?
I can't access the admin panel or ssh anymore.
- StephenBApr 24, 2017Guru - Experienced User
One option is to use paid support (my.netgear.com). Ask about per-incident.
- MarkPearceApr 26, 2017Aspirant
Thanks StephenB, I didn't realise that there was a per case option with support, I ws on the verge of getting support involved but decided that i would try a final factory reset.
I have managed to resolve by doing a factory reset, I was putting off doing it becuase I needed to copy off all my data first (I do have a remote backup but currently no network between the two NAS drives to restore from, so I put asside a few hours yesterday and copied all the data to a USB drive, reset to factory settings and then restored my backup and copied back my files, all now appears to be working OK.
I noticed that OS 6.7 has been withdrawn, should I be worried that I am on this version now?
Thanks for all the help and patience...
Mark
