aniraghome
Jul 23, 2024Tutor
readynas314 not powering on
Hi NAS experts I have a readynas 314 bought 2013-14 it has been good so far but yesterday it did not turn on meaning did not power on. It was connected to ups. Tried below did not turn on 1. I trie...
Sandshark
Jul 26, 2024Sensei
A memory issue usually results in the system locking up, not shutting down. But if you have compatible replacement RAM, then you can try it.
aniraghome
Jul 26, 2024Tutor
This is another area i am struggling its easier to find ram for pcs but not nas. Where and what can i buy.
- SandsharkJul 26, 2024Sensei
There is nothing special about the RAM in a NAS vs. that in a PC. Just open the unit up and see what's currently in it.
My statement was "if you have compatible RAM", as in already own some. I doubt seriously that a RAM replacement will fix your issue, so you're likely just throwing money away by trying if you have to buy it. Had you originally said you had a second power supply and using it changed nothing, I wouldn't have suggested buying yet another, either.
- aniraghomeJul 27, 2024TutorWell i ordered one ram but, its ok if it doesnt work i will return it.i returned the brick as well. I want to try all options possible before i have none left and a buy a new one. So no worries and thank you for your inputs.
