aniraghome
Jul 24, 2024Tutor
readynas314 not powering on
Hi NAS experts I have a readynas 314 bought 2013-14 it has been good so far but yesterday it did not turn on meaning did not power on. It was connected to ups. Tried below did not turn on 1. I trie...
Sandshark
Jul 27, 2024Sensei - Experienced User
There is nothing special about the RAM in a NAS vs. that in a PC. Just open the unit up and see what's currently in it.
My statement was "if you have compatible RAM", as in already own some. I doubt seriously that a RAM replacement will fix your issue, so you're likely just throwing money away by trying if you have to buy it. Had you originally said you had a second power supply and using it changed nothing, I wouldn't have suggested buying yet another, either.
aniraghome
Jul 27, 2024Tutor
Well i ordered one ram but, its ok if it doesnt work i will return it.i returned the brick as well. I want to try all options possible before i have none left and a buy a new one. So no worries and thank you for your inputs.
