sfy
Jul 28, 2015Aspirant
Replacing NV+ with 104 after PSU failure. #25507979
Can I install the old disks in the new box without losing data
mdgm-ntgr
Jul 28, 2015NETGEAR Employee Retired
The RAID format and filesystem are different.
However if you purchase the 104 you could enquire about purchasing data recovery services and what is involved.
You would need somewhere the data could be copied off to (e.g. a USB disk) and to not insert the disks into the new NAS until prompted to by support.
sfy
Jul 29, 2015Aspirant
It doesn't appear possible to obtain a replacement PSU for the NV+. Is that the case?
- DaneAJul 29, 2015NETGEAR Employee Retired
Hi sfy,
Is your NV+ a v1 or v2? You can verify it by reading this link below:
http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
If ever you have an NV+ v1, kindly access this forum link below:
Service Action to Prevent PSU Failures in ReadyNAS NV/NV+
If ever the serial number of your NV+ falls within the affected range, kindly contact Netgear Support for a possible replacement of the PSU:
http://support.netgear.com/general/contact/#tab-call
DaneA
Netgear Community team
- StephenBJul 29, 2015Guru - Experienced User
Also some NV+ are still under warranty. So you might check warranty status with Netgear.
- shaneyoulJul 29, 2015Aspirant
It appears to be a V1
The serial number I have is not in the format in the article. It is 23J<reset of serial removed by moderator>
- mdgm-ntgrJul 29, 2015NETGEAR Employee Retired
Yes, I looked that up and saw that you had a unit out of warranty.
Some older units had the serial number as the MAC address and a specific range of those units were shipped with a defect that could lead to premature fail of the PSU. Your unit is clearly not in the affected range, but if hardware is going to fail the PSU in a PC is a common component that can fail.
