sfy
Jul 28, 2015Aspirant
Replacing NV+ with 104 after PSU failure. #25507979
Can I install the old disks in the new box without losing data
DaneA
Jul 29, 2015NETGEAR Employee Retired
Hi sfy,
Is your NV+ a v1 or v2? You can verify it by reading this link below:
http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
If ever you have an NV+ v1, kindly access this forum link below:
Service Action to Prevent PSU Failures in ReadyNAS NV/NV+
If ever the serial number of your NV+ falls within the affected range, kindly contact Netgear Support for a possible replacement of the PSU:
http://support.netgear.com/general/contact/#tab-call
DaneA
Netgear Community team
shaneyoul
Jul 29, 2015Aspirant
It appears to be a V1
The serial number I have is not in the format in the article. It is 23J<reset of serial removed by moderator>
- mdgm-ntgrJul 29, 2015NETGEAR Employee Retired
Yes, I looked that up and saw that you had a unit out of warranty.
Some older units had the serial number as the MAC address and a specific range of those units were shipped with a defect that could lead to premature fail of the PSU. Your unit is clearly not in the affected range, but if hardware is going to fail the PSU in a PC is a common component that can fail. - JennCJul 30, 2015NETGEAR Employee Retired
Hi shaneyoul,
Support center already issued a replacement, see RMA 1553537 at RMA status
I think they will still give replacement for the PSU as long as they still have stocks available, but this is only for PSU not for chassis. Please check your supoport case again too.
